I have a subscribt problem in the following equation:
ms car =
SUM(tours ij opeak[i!,J!,car]+tours ij peak[i!,J!,car]) / SUM(tours ij opeak[i!,J!,mode!]+tours ij peak[i!,J!,mode!])
When I check the syntax the equation is ok, when I check the model it isn't.
The error message is the following: -i-appears more than once on LHS.
What does it mean? Did anybody have similar problems?
Greetings,
Anna
Subscribt Problems
