Using DLL with WCF Ajax
yobiman
Post by yobiman »
I am trying to integrate Vensim into a WCF application that I am developing.. I have IIS set up on my XP machine and am developing the application as a prototype.
I have been trying to replicate the Csharp dll model shipped with the latest version of DSS but cannot seem to get it working...
I have copied the VensimDLLWrapper.cs file into a class and add "Using VensimDLLWrapperAPI" to my declaration
When I was unable to get the process working through a WCF interface, I tried creating a simple webform with the following code to see if the basic "vensim_command" was working. Given that "0" was returned to TextBox1, I can only assume it isn't
Any help with this would be much appreciated
Many thanks
___________________
using System;
using System.Collections;
using System.Configuration;
using System.Data;
using System.Linq;
using System.Web;
using System.Web.Security;
using System.Web.UI;
using System.Web.UI.HtmlControls;
using System.Web.UI.WebControls;
using System.Web.UI.WebControls.WebParts;
using System.Xml.Linq;
using VensimDLLWrapperAPI;
namespace TolagaWare
public partial class WebForm1 : System.Web.UI.Page
protected void Page_Load(object sender, EventArgs e)
string strVensimCommand;
string strModelPath = "C:\\Program Files\\Vensim\\dll\\WORLDAPP.VPM";
strVensimCommand = string.Concat("SPECIAL>LOADMODEL|", strModelPath);
int nResult = VensimDLLWrapper.vensim_command(strVensimCommand);
this.TextBox1.Text = nResult.ToString();
there is not enough in what you sent to indicate what the problem is. Normally you would be using com.vensim.Vensim not VensimDLLWrapperAPI. Check with the java example to see if that is working.
Please note that the Vensim DLL that comes with Vensim DSS is not licensed for use with Web Servers. While you can use this for development on your own computer with Vensim DSS installed, it may not be open to access from any other user.
yobiman
Post by yobiman »
Thanks Bob,
Your response was helpful. It is working now
