displaying a graph as output object
I have a slight problem displaying a graph as output object.
If I display the graph from the graph editor, it diplays it with the right size, width and height from the graph editor, but if
I display it as an output object, it displays it always with the same size for instance when using the synthesim mode.
I would like that the output object be the same as when displayed with the graph editor.
Joined a simplistic model that illustrates the problem.
Thanks in advance.
graph_example.mdl
(1.63 KiB) Downloaded 265 times
Lee Jones
Post by Lee Jones »
I hope I have not missed the point here, but the graph as displayed in the output object will take the size of the output object. To change the size of the output object, click on "Move/Size Words and Arrows" from the tool bar and click and drag the "handle" for the object (bottom right).
Lee
display of graph
Hi Lee
Thank you very much.
Very easy to do, I did not noticed the handle on the object when clicking on the move/size button.
Best regards.
