How to access subscripts control dialog in VenApp?
newbie
Post by newbie »
I am trying to build a VenApp where the user can update the range for one of the subscripts. How can I do this?
Thanks,
use the SPECIAL>SUBSCRIPT command.
newbie
Post by newbie »
I have tried using that but it doesn't work.
There is indeed a problem with the SPECIAL>SUBSCRIPT command. This will be fixed in the next release which should be Jan 16 or so.
newbie
Post by newbie »
Hi Bob,
Just wanted to get an update from you regarding this fix as you had mentioned earlier. I have downloaded the last release 5.8d, but the issue still exists. Could you please check and let me know.
Thanks.
I just tried this and it seems to be working fine in 5.8d. The format for the command is
BUTTON,"Set Subscripts",34,43,8,3,,,SPECIAL>SUBSCRIPT|?,
to bring up a list of all subscripts of
BUTTON,"Set Subscripts",34,43,8,3,,,SPECIAL>SUBSCRIPT|Firm|?,
to select which firm (assuming Firm is a subscript range).
newbie
Post by newbie »
Hi Bob,
Thanks for the update. I tried this command and it works fine and brings up the Projects subscript window.
string strVensimCommand = "SPECIAL>SUBSCRIPT|PROJECTS|?,";
Now, if I want to set the value of the subscript PROJECTS then how can I do that?
In the model, Projects is defined with this equation: (project1-project5).
I want to be able to change this equation for Projects dynamically from code. so, if I want to set the equation to (project1-project10) I should be able to do that.
Thanks.
This is just
SPECIAL>SUBSCRIPT|PROJECTS|Project4
etc.
