how can I do that ?
almoon
how can I do that ?
Post by almoon »
i was working on several model but each time i was press new to draw an new one then i realise that i should make them all in one as a several views so how can u move them so i can see them from the views in the bottom bar plzzzzzzz
Open the model you want to add from, use Edit>Select All then Edit copy, now open the model you want to add to, create a new view, then use Edit>Paste.
almoon
Post by almoon »
I tried that but it didn't work ..
when i open the the view i wants to pasts to i couldn't do the paste...
You need to keep Vensim open - use the file menu to open different models.
almoon
Post by almoon »
still not working, so is there is any other way ?
Chapter 8 in the User's Guide describes how to do this.
