i was working on several model but each time i was press new to draw an new one then i realise that i should make them all in one as a several views so how can u move them so i can see them from the views in the bottom bar plzzzzzzz
Open the model you want to add from, use Edit>Select All then Edit copy, now open the model you want to add to, create a new view, then use Edit>Paste.
