I am new to Vensim and trying to compare multiple variables to each other to find the maximum value. Currently I am doing this by using MAX(Var 1, MAX(Var 2, Var 3)) but want to be able to get the maximum of (Var 1, Var 2, Var 3). I believe that VMAX can be use to do this, but have not had success so far in using VMAX. Do the variables that VMAX is comparing have to be is a specific format, such as a subscripted or scripted variables.
VMAX(X[r!])† Takes the maximum of X over the subscript range r.
VMAX†(x[i!]) MAXimum Over Subscript Range
Returns the maximum value of the elements of an array over the Subscript Range(s) marked with exclamation ! marks.
Units: VMAX(unit) --> unit (the output has same units as the input)
Example
VMAX (x[i!]) is equal to MAX(x[one] , MAX(x[two] , MAX..., x[n]))...).
VMax Help
vmax help
One easy solution is to build a subscripted variable that has the same unit dimension than the xi.
For instance if you have the variables x1,x2,x3 etc. with dimension people for instance up to a maximum of n, then build the subscript sube s1-sn, and create the variable x subscripted by sube, x[sube] with dimension people, then make x[s1] = x1, x[s2] = x2 etc...
Then the maximum of (x1,x2,... xn) will be equal to
vmax(x[sube!]).
Il may be too useful to think about the meaning of these unsubscripted xi. They should have a real world meaning and the fact than these xi exist may be the proof that your model has a bad structure and that your xi should have been already declared in a subscripted way right at the befinning.
Then the xi should not even exist and the x should replace them.
[Edited on 8-4-2009 by LAUJJL]
vmax(x[sube!]).
