With command scripts is it possible to update an equation (specifically a string) without the model doing a simulation first?
For Background: We have a single model (mdl) which we use for multiple countries but each country has a different excel input file. We copy the file over into separate folders where the excel input file resides and want to update a variable with the name of the input file in that folder but if I use the SIMULATE>SETVAL it tries to run the model and falls over as the variable name is wrong. Is there an equivalent command I can use without the model running first? I know we could use the same name for the input file for every country but would prefer to avoid that if possible!
Thanks for your help in advance.
