VENSIM SIMUL8 timing issue using DLL
joe
Post by joe »
I am using VENSIM to generate patient demand along with other more SD things and then using SIMUL8 to treat the patients.
I am using Excel to achieve this as I am not (hopefully) trying anything too complicated. What I thought of doing was using VENSIM's game function, the game generates the demand I then run Simul8 and determine the number of patients treated.
Below is the code that I thought would work but I have obviously missed something:
result = vensim_get_val("Available for treatment", timeval)
If result = 1 Then
stime$ = timeval
Worksheets("Sheet1").Cells(21, 10) = stime$
Worksheets("Sheet1").Cells(4, 2) = stime$
End If
Call Trial
num$ = Worksheets("Sheet1").Cells(4, 6)
comstr$ = "SIMULATE>SETVAL|TREATED= " + num$
result = vensim_command(comstr$)
If result = 0 Then Exit Sub
result = vensim_get_val("Treated", timeval)
If result = 1 Then
stime$ = timeval
Worksheets("Sheet1").Cells(21, 11) = stime$
End If
The "Call Trial" line relates to the Simul8 run. The "Worksheets("Sheet1").Cells(4, 6)" is where the output from Simul8 is located.
VENSIM doesn't wait for the value to be returned before going to the next line consequently the number of people treated isn't updated.
Any advice or guidance would be appreciated
Many thanks
Joe
Is the code stepping over the "Call Trial" line?
And how are you calling Simul8 (it would be handy to see the routine where you call Simul8)?
joe
Post by joe »
Hi Tony,
This is the code used to run the Simul8 trial:
Private Sub Trial()
MYSIMUL8.ResetSim (0)
MYSIMUL8.TrialSim 50, False
End Sub
Simul8 runs ok and it posts the number of people treated back but as I mentioned before whilst this code is running VENSIM has already gone through the rest of the code.
Are there any techniques to freeze VENSIM until the Simul8 trial is complete. Then restart at the next line?
VENSIM and SIMUL8 are already open before the above code is run. I thought about trying to put in some kind of delay after the simul8 line is reached but this didn't have an effect.
Below is the entire routine if needed:
Private Sub game()
Dim timeval As Single
result = vensim_be_quiet(2)
result = vensim_command("SPECIAL>LOADMODEL|C:\Documents and Settings\Joe\Desktop\Composite\simplemodel.vpm")
Worksheets("Sheet1").Activate
result = vensim_command("SIMULATE>RUNNAME|test")
num$ = Worksheets("Sheet1").Cells(15, 9)
comstr$ = "SIMULATE>SETVAL|INTERVENTION= " + num$
num$ = Worksheets("Sheet1").Cells(8, 9)
result = vensim_command("GAME>GAMEINTERVAL|" + num$)
result = vensim_command("MENU>GAME")
result = vensim_get_val("Time", timeval)
If result = 1 Then
stime$ = timeval
Worksheets("Sheet1").Cells(21, 9) = stime$
End If
If result = 1 Then
stime$ = timeval
End If
Call Trial
If result = 1 Then
stime$ = timeval
End If
End Sub
The problem here is not with Vensim. You need to make the function call to Simul8 and wait for it to finish.
What is the "false" in the line below? Only asking in case it is a wait flag.
Another solution would be to set some cell to -1 before calling Simul8. Now run the Simul8 code and make sure it overwrites the -1 with 1, and have a loop in your code above that monitors the cell contents and exits the loop when it finds a 1.
For example, the following monitors a cell, and sleeps for 100 milliseconds before checking the contents again. If Simul8 can set the cell to anything other than -1, the loop will end.
Private Declare Sub Sleep Lib "kernel32" (ByVal dwMilliseconds As Long)
Worksheets("Sheet1").Cells(100, 100) = -1
Call Trial
while ( Worksheets("Sheet1").Cells(100, 100) = -1 )
Sleep(100)
wend
I can't follow your code - you need to do the following
MENU>GAME
then in a loop
get value from vensim
call some other function to do some computation
use SIMULATE>SETVAL
GAME>GAMEON
check to see if finished
I do not see a GAMEON command anywhere. You also need to make sure the variable you set is a gaming variable and not a constant.
joe
Post by joe »
The variable I am trying to change is a gaming variable. I use MENU>GAME in a previous piece of code see below:
Private Sub game()
result = vensim_command("GAME>GAMEINTERVAL|1")
If result = 1 Then
stime$ = timeval
End If
If result = 1 Then
stime$ = timeval
End If
comstr$ = "SIMULATE>SETVAL|TREATED = " + num$
If result = 1 Then
stime$ = timeval
End If
End Sub
Then I use the following code:
Private Sub Continue()
Dim i As Single
i = Worksheets("Sheet1").Cells(9, 9)
result = vensim_command("GAME>GAMEON")
'result = vensim_command("GAME>BACKUP") to back up
num$ = Worksheets("Sheet1").Cells(10, 9)
result = vensim_get_val("time", timeval)
If result = 1 Then
stime$ = timeval
Worksheets("Sheet1").Cells(i, 9) = stime$
End If
If result = 1 Then
stime$ = timeval
Worksheets("Sheet1").Cells(i, 10) = stime$
End If
If result = 1 Then
stime$ = timeval
Worksheets("Sheet1").Cells(i, 11) = stime$
End If
i = i + 1
Worksheets("Sheet1").Cells(9, 9) = i
End Sub
Sorry for the amount of code.
Joe
the continue sub looks OK except that you need to have SIMULATE>SETVAL before GAME>GAMEON, not after. so you must have a loop somewhere that looks like
do
call simul8 code
call continue subroutine
end do
As Tony suggests - make sure the simul8 code finishes before returning to call the continue subroutine.
