Equations for each sketch
almoon
Post by almoon »
I draw several sketchs and when i need to see the equations it give me all the models equation so how can i see each sketch equation separately ?
If you use the document tool, there is an option here to only show the equations on the current view. Have you tried that?
almoon
Post by almoon »
Thank you very much
when I press DOC option I got the following :
Display
Formatting
Multiple equations option
So what should i choose from each one to get what i want ?
In "Multiple equations options" there should be a tickbox for "vars in current view".
almoon
Post by almoon »
I dont have this option so what shall i do ?
Select everything in the sketch and use Edit>Group and give a new group name. Then document that group (another document option).
almoon
Post by almoon »
Yes it is work thank you veyr much :)
Balthor12
Newbie
Post by Balthor12 »
This is working..Thanks for the tips, now its done...
Regards
Balthor
____
http://simulationpretimmobilier.net]simulation de pret
[Edited on 9-29-2009 by Balthor12]
