after running a monte carlo simulation(Sensitivity), I am trying to display the histrogram in a exact time point, to exhibite the distribution e.g. in a certain time.
The default histogram in PLE Plus is set for special time so just go to Time Axis on the control panel and set Special Time to the value you want. For Pro/DSS you will need to right click on the bar tool and ask for a histogram across sims. You can set a time there as well or use Special time.
