About vensim graph
lynchyml
About vensim graph
Post by lynchyml »
Vvensim graph can show 6 varibles once,what are we going to do if we want to show 8 or 10 varibles in a graph
[Edited on 9-16-2009 by lynchyml]
vensim graph.rar
(7.66 KiB) Downloaded 484 times
The custom graph dialog editor only has 6 slots for variables. To show more you will need to edit the .vgd file directly (not supported in PLE or PLE Plus). See Chapter 15 of the reference manual for details.
Alternatively simply select all the variables you want to see and use the graph tool on the toolbar.
lynchyml
Post by lynchyml »
thank you!
the variables are in different views, so I can not use the second measure
lynchyml
Post by lynchyml »
I just reade chapter15 of the referenc manual for details, but I still a little confused, I am expecting a detail measure ?
thx a lot!
I am afraid I didn't understand you question, but you can put variables together in a view using the Shadow Variable tool which might be easier than editing the .vgd file directly.
lynchyml
Post by lynchyml »
thank you for your reply.
put variables together in a view is an effective way,but I still want to know how to editing the .vgd file directly.
To edit the .vgd on the graphs tab of the control panel click Save>As then use a text editor you like (Vensim's if you like) and modify the file according to the rules in Chap 15 of the Reference Manual). - Again only for Pro/DSS.
