hello everyone!
The time range of historical data is 2000-2006, but the graph show all the values from 2000-2020.
thank you very much!
Compare the Model's Behavior to Historical Data
- Snap1.rar
- (8.09 KiB) Downloaded 527 times
thank you for your reply.
After reading chapter12 and 13, I know there are two methods to select a time range:
first: time axis tab of the controp panel as you said.
second:drag the mouse.
the problem is :
the two methods will change the time range of all varibles in the graph, but I only have to change one varible's time range.
time range of one varible is 2000-2006
time range of the other varible is 2000-2020
both the varibles will display in one graph
hoping for futher explain
[Edited on 9-24-2009 by lynchyml]
the problem is :
