I have my model calculating 6 variables dynamically. I want to select the least value of these variables at a particular point of time. I want to know if there is any direct function to do this are we need to put up our own lops?.
Krishna.
How to pick the minimum value from say 6 values?
minimum value
I you have at least the Pro Vensim version you can too put the 6 variables in an array variable with 1 subscript having 6 possible values like value = (v1-v6) then calculate the minimum of the arrays values minimum = vmin(variable[value!]).
[Edited on 2-3-2010 by LAUJJL]
