Hey guys
Is there a way of rounding the value of levels to for example 2 decimal places?
YR
Rounding the value of levels.
If your question is about display use %.2f as the format for the table tool or custom tables/reports. If you are asking about computation then something similar to what JJ such as
rounded level = INTEGER(level * 100.0 + 0.5)/100.0
should work, though I can't think of a case where this would be very helpful.
If you're using Vensim DSS, it's handy to put JJ's formula in a macro, like
:MACRO: ROUND(x,digits)
ROUND = INTEGER(x*10^digits+0.5)/10^digits
~ x
:END OF MACRO:
a test:
digits=
1
~ [-2,2,1]
test x=
ROUND(453.123,digits)
Note that precision is also limited by the floating point format.
~ x
:END OF MACRO:
a test:
digits=
1
~ [-2,2,1]
test x=
