Model Time
Filipe
Model Time
Post by Filipe »
Hello.
I am modelling an acquisition that will be made 3 years after I start running my model. Is there a way of modelling this?
I have a "acquisition variable" that would be set up to 1 after 3 years. Imagined being something like
IF THEN ELSE ( TIME = 3, 1, 0)
but this does not work.
Thank you so much!!
If you want it to be 0 until time 3, then 1 thereafter, use STEP(1, acquisition time) with acquistion time = 3
Another option would be to use a level:
AcquisitionIsMade = INTEG( Acquisition Rate, 0) ~ dmnl
AcquisitionRate = PULSE(acquisition time,TIME STEP)/TIME STEP ~ 1/year
Filipe
Post by Filipe »
Tom,
Thank you for your reply.
The idea is to make it 1 only in Time 3, then is set back to 0. I am only investing once.
Thank you!
Ahh, OK. Then your IF THEN ELSE should work. If not, it could be due to roundoff error: if Time isn't exactly equal to 3, the equation will fail, even though 3.0001 might be close enough from your perspective. As an alternative, you can do one of two things:
IF THEN ELSE( time > AqTime-TIME STEP/2 :AND: time <= AqTime+TIME STEP/2, 1, 0)
PULSE(AqTime,TIME STEP)
Filipe
Post by Filipe »
Tom,
It's working!
Thank you
