Interface control for Lookup Table
Moderator: Administrator
maxin454
Post by maxin454 »
Hi. I tried to create an interface control in Sable for a variable whose type is "Lookup". I do not know how to do it. Does Sable support such functionality? Thanks.
Yes.
Insert a button, and on the button you need a Venapp command. The command should be
SIMULATE>1TABCHG|<INSERT_YOUR_LOOKUP_TABLE_NAME_HERE>
Let us know how you get on.
maxin454
Post by maxin454 »
Thank you, Tony. That would work. However it is slightly different than what I want to achieve (I did not describe it clearly). Let me describe what I need more specifically.
I would like to change a variable value whose type is a Lookup but I only want to change only one entry in that Lookup table. For example, the lookup table is
Input Output
1 100
2 200
3 300
Now, I only want to change the Output of Input 2 from 200 to 500. How can I set up a radio button, or a check box, or even a slider (either one would work) and when it is checked, the Output of Input 2 will be changed to 500?
Thanks.
[Edited on 7-13-2010 by maxin454]
You cannot do this with Sable. Only the whole lookup editor will appear.
