I use Vensim PLE.
Can I define a variable as a stochastic by using probability distribution functions.
Please note that I cannot use MACROs in Vensim PLE.
kind regards
Lukas
Probability distribution and Vensim PLE
Often you can transform a uniform random variable to some other desired distribution, using the cumulative distribution - either an analytic expression or a lookup table.
Also, in continuous-time models you'll want noise that has some frequency cutoff. See http://models.metasd.com/2010/03/pink-noise/
