vensim link matlab
vensim link matlab
hi,My vensim is DSS & Ihave win 7 (64bit),How Can I link vensim to matlab?
There is already a thread on this subject, have a look at
http://www.ventanasystems.co.uk/forum/v ... php?t=4181
You don't open the .dll as a program; you load it via code in matlab - see http://www.mathworks.com/access/helpdes ... 43202.html for details. Your matlab code will be fairly close to the code in the .dll examples that install with Vensim (look in the dll folder in your Vensim program directory).
A good first step would be to see if you can load the library and view the functions, as in
http://www.mathworks.com/access/helpdes ... tml#f42310
if not(libisloaded('libmx'))
hfile = [matlabroot '\extern\include\matrix.h'];
loadlibrary('libmx', hfile);
end
libfunctionsview libmx
Replace libmx above with ven32dll (which should be in your windows directory, e.g. c:\windows\system32 on XP) and hfile with C:\Program Files\Vensim\dll\vendll.h (or the path to your dll folder in the Vensim program directory).
Hopefully this will work; unfortunately I don't have a copy of Matlab to test with.
end
Thank you Tom for your help
I run these two (as you said):
end
if not(libisloaded('ven32dll'))
loadlibrary('ven32dll', hfile);
end
libfunctionsview ven32dll
but for both of them, matlab gives me this error:
??? Error using ==> loadlibrary at 263
microsoft visual C++ 2005 is required to use this feature.
I checked my computer & I have microsoft visual C++ 2005.
even I installed it again after this error but it gives me that error again!!!!!!!!
end
end
1)My previous verson of Matlab-soft was 2008a,I unistalled it & installed Matlab 2010(R 2009a), then after run this program:
end
it gives me :
Warning: Warnings messages were produced while parsing. Check the functions you
intend to use for correctness. Warning text can be viewed using:
[notfound,warnings]=loadlibrary(...)
> In loadlibrary at 399
And it opens a table (it’s title Function Is Library libmx)
And when run:
end
It gives me :
??? Error using ==> loadlibrary at 480
There was an error loading the library "ven32dll"
The specified module could not be found.
Caused by:
Error using ==> loaddefinedlibrary
2) I couldn’t open these files: http://www.mathworks.com/access/helpdes ... 43202.html
Can any one help me please ?
end
it gives me :
And when run:
end
It gives me :
Caused by:
Sounds like you need to check your system directories to see if the dll is installed. Or, just reinstall Vensim, and be sure that the .dll option is checked.
now I try this :
>> if not(libisloaded('vendll32'))
loadlibrary('vendll32', hfile);
end
libfunctionsview vendll32
it gives me :
There was an error loading the library "vendll32"
end
it gives me :
Sorry about the name mistake. Did you look in your system folders to see if the .dll is installed?
I think your header file (matrix.h) is the wrong one. You got that one from the example with the libmx library on the mathworks page, didn't you? That won't work for vensim.
The correct header file is vendll.h, it can be found in the same folder as vendll32.lib.
Now, if you navigate to that folder after opening matlab, you can simply type
loadlibrary('vendll32','vendll').
Thank you
Yes,I see the both of them in DLL subdirectory: VenDLL32.lib & Vendll.h
Now I try that with full address of Vendll.h:
hfile = ['C:\Program Files (x86)\Vensim\dll\vendll.h'];
loadlibrary('vendll32',hfile);
end
It’s response is :
Error loading library intermediate output follows.
The actual error is at the end of this output.
Type 'HWND' was not found. Defaulting to type error.
Found on line 111 of input from line 110 of file C:\\Program Files (x86)\\Vensim\\dll\\vendll.h
Found on line 117 of input from line 116 of file C:\\Program Files (x86)\\Vensim\\dll\\vendll.h
Found on line 128 of input from line 127 of file C:\\Program Files (x86)\\Vensim\\dll\\vendll.h
Found on line 136 of input from line 135 of file C:\\Program Files (x86)\\Vensim\\dll\\vendll.h
Found on line 142 of input from line 141 of file C:\\Program Files (x86)\\Vensim\\dll\\vendll.h
Found on line 153 of input from line 152 of file C:\\Program Files (x86)\\Vensim\\dll\\vendll.h
??? Error using ==> loadlibrary at 428
Building vendll32_thunk_pcwin64 failed. Compiler output is:
vendll32_thunk_pcwin64.c
C:\Program Files\MATLAB\R2010a\extern\include\vendll.h(110) : error C2146: syntax error : missing
')' before identifier 'pwindow'
C:\Program Files\MATLAB\R2010a\extern\include\vendll.h(110) : error C2081: 'HWND' : name in formal
parameter list illegal
C:\Program Files\MATLAB\R2010a\extern\include\vendll.h(110) : error C2061: syntax error :
C:\Program Files\MATLAB\R2010a\extern\include\vendll.h(110) : error C2059: syntax error : ';'
C:\Program Files\MATLAB\R2010a\extern\include\vendll.h(110) : error C2059: syntax error : ','
C:\Program Files\MATLAB\R2010a\extern\include\vendll.h(110) : error C2059: syntax error : ')'
C:\Program Files\MATLAB\R2010a\extern\include\vendll.h(116) : error C2146: syntax error : missing
C:\Program Files\MATLAB\R2010a\extern\include\vendll.h(116) : error C2081: 'HWND' : name in formal
C:\Program Files\MATLAB\R2010a\extern\include\vendll.h(116) : error C2061: syntax error :
C:\Program Files\MATLAB\R2010a\extern\include\vendll.h(116) : error C2059: syntax error : ';'
C:\Program Files\MATLAB\R2010a\extern\include\vendll.h(116) : error C2059: syntax error : ')'
C:\Program Files\MATLAB\R2010a\extern\include\vendll.h(127) : error C2146: syntax error : missing
')' before identifier 'window'
C:\Program Files\MATLAB\R2010a\extern\include\vendll.h(127) : error C2061: syntax error :
identifier 'window'
C:\Program Files\MATLAB\R2010a\extern\include\vendll.h(127) : error C2059: syntax error : ';'
C:\Program Files\MATLAB\R2010a\extern\include\vendll.h(127) : error C2059: syntax error : ','
C:\Program Files\MATLAB\R2010a\extern\include\vendll.h(127) : error C2059: syntax error : ')'
C:\Program Files\MATLAB\R2010a\extern\include\vendll.h(135) : error C2146: syntax error : missing
C:\Program Files\MATLAB\R2010a\extern\include\vendll.h(135) : error C2081: 'HWND' : name in formal
C:\Program Files\MATLAB\R2010a\extern\include\vendll.h(135) : error C2061: syntax error :
C:\Program Files\MATLAB\R2010a\extern\include\vendll.h(135) : error C2059: syntax error : ';'
C:\Program Files\MATLAB\R2010a\extern\include\vendll.h(135) : error C2059: syntax error : ','
C:\Program Files\MATLAB\R2010a\extern\include\vendll.h(135) : error C2059: syntax error : ')'
C:\Program Files\MATLAB\R2010a\extern\include\vendll.h(141) : error C2146: syntax error : missing
C:\Program Files\MATLAB\R2010a\extern\include\vendll.h(141) : error C2081: 'HWND' : name in formal
C:\Program Files\MATLAB\R2010a\extern\include\vendll.h(141) : error C2061: syntax error :
C:\Program Files\MATLAB\R2010a\extern\include\vendll.h(141) : error C2059: syntax error : ';'
C:\Program Files\MATLAB\R2010a\extern\include\vendll.h(141) : error C2059: syntax error : ')'
C:\Program Files\MATLAB\R2010a\extern\include\vendll.h(152) : error C2146: syntax error : missing
C:\Program Files\MATLAB\R2010a\extern\include\vendll.h(152) : error C2081: 'HWND' : name in formal
C:\Program Files\MATLAB\R2010a\extern\include\vendll.h(152) : error C2061: syntax error :
identifier 'window'
C:\Program Files\MATLAB\R2010a\extern\include\vendll.h(152) : error C2059: syntax error : ';'
C:\Program Files\MATLAB\R2010a\extern\include\vendll.h(152) : error C2059: syntax error : ','
C:\Program Files\MATLAB\R2010a\extern\include\vendll.h(152) : error C2059: syntax error : ')'
vendll32_thunk_pcwin64.c(87) : error C2065: 'HWND' : undeclared identifier
vendll32_thunk_pcwin64.c(87) : error C2146: syntax error : missing ';' before identifier 'p1'
vendll32_thunk_pcwin64.c(87) : error C2065: 'p1' : undeclared identifier
vendll32_thunk_pcwin64.c(88) : error C2275: 'int32' : illegal use of this type as an expression
vendll32_thunk_pcwin64.c(44) : see declaration of 'int32'
vendll32_thunk_pcwin64.c(88) : error C2146: syntax error : missing ';' before identifier 'p2'
vendll32_thunk_pcwin64.c(88) : error C2065: 'p2' : undeclared identifier
vendll32_thunk_pcwin64.c(91) : error C2065: 'p1' : undeclared identifier
vendll32_thunk_pcwin64.c(91) : error C2146: syntax error : missing ')' before identifier 'HWND'
vendll32_thunk_pcwin64.c(91) : error C2065: 'HWND' : undeclared identifier
vendll32_thunk_pcwin64.c(91) : error C2100: illegal indirection
vendll32_thunk_pcwin64.c(91) : error C2059: syntax error : ')'
vendll32_thunk_pcwin64.c(91) : error C2297: '*' : illegal, right operand has type 'const char *'
vendll32_thunk_pcwin64.c(92) : error C2065: 'p1' : undeclared identifier
vendll32_thunk_pcwin64.c(93) : error C2065: 'p2' : undeclared identifier
vendll32_thunk_pcwin64.c(94) : error C2065: 'p2' : undeclared identifier
vendll32_thunk_pcwin64.c(95) : error C2059: syntax error : ','
vendll32_thunk_pcwin64.c(95) : error C2146: syntax error : missing ')' before identifier 'HWND'
vendll32_thunk_pcwin64.c(95) : error C2065: 'HWND' : undeclared identifier
vendll32_thunk_pcwin64.c(95) : error C2059: syntax error : 'type'
vendll32_thunk_pcwin64.c(99) : error C2061: syntax error : identifier 'int32int32int32int32Thunk'
vendll32_thunk_pcwin64.c(99) : error C2059: syntax error : ';'
vendll32_thunk_pcwin64.c(99) : error C2059: syntax error : 'type'
vendll32_thunk_pcwin64.c(146) : error C2065: 'HWND' : undeclared identifier
vendll32_thunk_pcwin64.c(146) : error C2146: syntax error : missing ';' before identifier 'p3'
vendll32_thunk_pcwin64.c(146) : error C2065: 'p3' : undeclared identifier
vendll32_thunk_pcwin64.c(153) : error C2065: 'p3' : undeclared identifier
vendll32_thunk_pcwin64.c(153) : error C2146: syntax error : missing ')' before identifier 'HWND'
vendll32_thunk_pcwin64.c(153) : error C2065: 'HWND' : undeclared identifier
vendll32_thunk_pcwin64.c(153) : error C2100: illegal indirection
vendll32_thunk_pcwin64.c(153) : error C2059: syntax error : ')'
vendll32_thunk_pcwin64.c(153) : error C2297: '*' : illegal, right operand has type 'const char *'
vendll32_thunk_pcwin64.c(154) : error C2065: 'p3' : undeclared identifier
vendll32_thunk_pcwin64.c(155) : error C2059: syntax error : ','
vendll32_thunk_pcwin64.c(155) : error C2146: syntax error : missing ')' before identifier 'HWND'
vendll32_thunk_pcwin64.c(155) : error C2065: 'HWND' : undeclared identifier
vendll32_thunk_pcwin64.c(155) : error C2059: syntax error : ')'
vendll32_thunk_pcwin64.c(155) : error C2146: syntax error : missing ';' before identifier 'fcn'
vendll32_thunk_pcwin64.c(155) : warning C4047: 'return' : 'int32' differs in levels of indirection
from 'int32 (__cdecl *)(int32,int32,int32,...)'
vendll32_thunk_pcwin64.c(155) : error C2065: 'p3' : undeclared identifier
vendll32_thunk_pcwin64.c(218) : error C2065: 'HWND' : undeclared identifier
vendll32_thunk_pcwin64.c(218) : error C2146: syntax error : missing ';' before identifier 'p0'
vendll32_thunk_pcwin64.c(218) : error C2065: 'p0' : undeclared identifier
vendll32_thunk_pcwin64.c(219) : error C2143: syntax error : missing ';' before 'type'
vendll32_thunk_pcwin64.c(220) : error C2143: syntax error : missing ';' before 'type'
vendll32_thunk_pcwin64.c(221) : error C2065: 'p0' : undeclared identifier
vendll32_thunk_pcwin64.c(221) : error C2146: syntax error : missing ')' before identifier 'HWND'
vendll32_thunk_pcwin64.c(221) : error C2065: 'H
end
It’s response is :
identifier 'window'
identifier 'window'
I delete:( these rows and where I see (HWND pwindow ) I substitute it with void*.
#ifndef HWND
#define HWND void *
#endif
hfile = ['C:\Users\mrj\Desktop\New folder (3)\vendll.h'];
end
??? Error using ==> loadlibrary at 474
Caused by:
even I uninstalled matlab 64(bit) & install 32bit.But it gives me the same error!!!!!!!:(
#ifndef HWND
#define HWND void *
#endif
end
Caused by:
It sounds like your modified vendll.h is now OK. What you may still be missing is vendll32.dll (not .lib) in your system path.
Maybe try giving it the full path then, e.g.
vendll = ['c:\windows\sysWOW64\vendll32.dll']; (or whatever the real path is)
loadlibrary( vendll , hfile);
Thank you Tom ,
I tried :
>> vendll=['C:\Windows\SysWOW64\venDLL32.dll']
vendll =
>> hfile=['C:\Program Files (x86)\Vensim\dll\vendll.h']
hfile =
>> loadlibrary('vendll',hfile)
> In loadlibrary at 394
??? Error using ==> loadlibrary at 422
Building vendll_thunk_pcwin64 failed. Compiler output is:
vendll_thunk_pcwin64.c
The same error!
I tried :
vendll =
hfile =
The same error!
it sounds like you are pointing to the original vendll.h file or perhaps you reinstalled Vensim and overwrote the one you had edited. You should probably edit the file and place it in a directory with other files you are using so that you can be sure you are pointing at your edited file at all times.
I think what Bob means is that you're back to using the original hfile = C:\Program Files (x86)\Vensim\dll\vendll.h where you should be using your modified hfile = C:\Users\mrj\Desktop\New folder (3)\vendll.h'
