Using Discrete Distributions in Sensitivity Analysis
YahyaRafique
Post by YahyaRafique »
Dear all,
I am trying to run a sensitivity analysis where some of the parameter I am using a discrete distribution rather than a continuous one.
for example I want a discrete random uniform distribution in the range [30,60] that select whole numbers only like 32,48,51 etc.
How would I do this for a parameter in a multivariate sensitivity analysis?
Thank you in advance...
YR
You will need to take the parameters and pass them through the INTEGER function in the model. eg if you had
constant = 1
you would need to have
constant = INIT(INTEGER(constant input))
constant input = 1
then run the sensitivity on constant input. Note the INIT function is just an efficiency thing that prevents the equation for constant from being computed at all times.
INIT = INITIAL
INITIAL always has to appear first in an equation. I sometimes add an INIT macro to my models, so that I can write things like relativeX = x/INIT(x)
:MACRO: INIT(x)
INIT = INITIAL(x)
~ x
:END OF MACRO:
YahyaRafique
Thanks guys..
YahyaRafique
But how would I round to one decimal place...
I am trying to use a beta distribution and want to round generated values between O and 1 to to one decimal place..thanks in advance
Use INTEGER(x*10+0.5)/10
