Hello All!
Is there a way to customize the axis, colors, scale etc. of the sensitivity and probability graphs (bar) generated after a sensitivity analysis in DSS?
I can customize the colors of the sensitivity graph only, but can´t remove the simulation name, change the axis names and some other aspects.
I also would like to change the title, remove the simulation name, change the colors e X-axis scale of the probability bar graph.
Any clues will be very welcome!
Thank you in advance.
George
Sensitivity Graphs Customization
You can use a custom graph - see the :CONFIDENCE keyword
http://www.vensim.com/documentation/ind ... ?24000.htm
You have to work with the .vgd in a text editor though.
