Excuse me, I have some problem when using Vensim
The problem will be described as the following.
The scenario is that when I click the "equation" button
The variable in the screen will be highlight...and why Vensim didn't show me the talking window which can let me input the equation ???
And Vensim seem be lock... nothing will happen !!!
Do I press some button to lock it ? How can I unlock it ?
This problem really drive me crazy, can someone tell me how to improve this problem?
Thanks you
Regard!!!!!!!!!!!!
Need some help...
Re: Need some help...
Can you let us know the following please.
1. What operating system are you using?
2. What version of Vensim?
3. Do you have multiple monitors set up?
4. Are you using a laptop in a docking station?
1. Vista
2. 5.10e(education)
3. In the precious use I actually set multiple monitors, the when I end the use of multiple monitors, the problem happened...
4. Yes
Thanks for your reply
Howard
2. 5.10e(education)
4. Yes
Howard
Try opening up the laptop screen, chances are the equation editor is appearing there.
Thanks !!!
But what's the meaning of "Try opening up the laptop screen, chances are the equation editor is appearing there."
My screen is always opening, and it means that when I click the "equation" and the screen will stop.
do you mean that I should open the control term of screen when I click the equation ???
Very Thanks for your help !!!!!
Vensim remembers where you had the equation editor open. If you have gone from multi-monitor to single monitor, and moved the editor in the past, it will still try to appear on the 2nd monitor.
Try the following.
1. Close Vensim.
2. Start notepad, edit the file called vensim.ini (click File->Open, type %APPDATA%\vensim\vensim.ini into the file open box).
3. Search the file for "EqedDim1" and "EqedDim2" in the INI file. Delete these two lines and save the file.
4. Start Vensim and the equation editor should appear again.
Try the following.
1. Close Vensim.
Thanks for your help.I finally successfully solve this problem
And I can continued to finish my final report
Thanks you again, and wish you always have a good fortune !!!
Howard
Howard
