With all the promises that the new mac operating system will enable you to run PC programmes does anyone know if people have tried running vensim on a mac and if so has it been workable?
David
Apple Mac
Re: Apple Mac
There is a native Vensim build for the Mac, you should be able to download it from
http://www.vensim.com/download.html
It's identical to the PC version (although there may well still be some bugs as it hasn't had the anywhere near the same amount of usage as the PC version has).
Re: Apple Mac
Thanks Tony. Will Sable also work on the Mac platform?
David
David
Re: Apple Mac
You can also run under emulation - VMware works well. For must purposes the native version is preferable though.
