Subscript operations
matin
Post by matin »
Hi all,
I am new to VENSIM. I receive the "Missing the closing bracket for a variable" error message, when I enter the equation below for a subscript variable:
IF THEN ELSE
((rand1 >
Cumulative Pn[n-2]) AND (rand1 < Cumulative Pn[n-1]), 1, 0))
while "n" is a subscript defined as:
n1-n1000
Obviously, I cannot have expressions like "n - 1" as the subscript in the equation. I wonder how I can implement this model.
Bests,
Matin
Re: Subscript operations
I'd do some subscript mapping. See the following post and report back if you can implement it successfully.
http://www.ventanasystems.co.uk/forum/v ... 584#p15537
The problem here is that you can't use algebraic expressions like [n-1] in subscripts. You need to use mapping (as in the prev/next example here http://www.ventanasystems.co.uk/forum/v ... f=2&t=4584) or use VECTOR ELM MAP if for some reason you do need to use expressions.
matin
Post by matin »
Many thanks for the hints.
By the way, is it possible to use DELAY FIXED function as follows to generate f(n-1):
f(n-1) = DELAY FIXED(f(n),1)
or DELAY FIXED can only be used when the parameter "n" is time? (In my model, "n" is NOT time)?
DELAY FIXED only works over time.
matin
Post by matin »
Hi again,
It seems that I have not implemented the model correctly, and I cannot figure out what is wrong.
I have defined three subscripts as follows:
n: (n3-n1000)
m: (m2-m999) -> n
k: (K1-k998) -> n
In order to access Cumulative Pn[n-1] and Cumulative Pn[n-2], I defined two new variables Cumulative Free Pn1[n] and Cumulative Free Pn2[n] as follows:
Cumulative Free Pn1[n] = INITIAL(Cumulative Free Pn[m])
Cumulative Free Pn2[n] = INITIAL(Cumulative Free Pn[k])
and then I use these two variables to calculate Promote free member[n]:
Promote free member[n] = IF THEN ELSE((rand1 < Cumulative Free Pn1[n]) :AND: (rand1 > Cumulative Free Pn2[n]), New random free members[n], 0)
Here, I have error messages like:
'Subscript of variable -Cumulative Free Pn- is a member of the -m- family when it should be a member of the -n- family'.
The model is attached.
I think you are trying to make it too complex.
Try again, but follow the example in the following post.
Or you could use something like
SUM(IF THEN ELSE(ID[n!] <= n - 1, pn free[n!], 0 ) )
and
SUM(IF THEN ELSE(ID[n!] <= n - 2, pn free[n!], 0 ) )
I think the problem may be that you're using three different ranges, (n3-n1000), (m2-m999), (K1-k998). If these are really different subsets of the same thing, so that you can refer to n-1 for example, you should define:
n : (n1-n1000)
nPrev = (n1-n999) -> nNext
nNext = (n2-n1000) -> nPrev
Then you can write things like:
x[n]=...
y[n1]=x[n1]
y[nNext]=x[nNext]+y[nPrev]
which is the equivalent of y(n)=y(n-1)+x(n) in more typical notation.
