COMBINING PULSE AND DELAY
irene
Post by irene »
hi,
I am new here and i have this problem. I have an inflow (order rate) to a level that is a pulse train (order rate = PULSE TRAIN( {1} , {1} , {7} , {100} ) but the outflow (order arrival rate) is a delay (outflow= DELAY FIXED( {order rate} , {20} , {0} ). I want to bring the model to equilibrium state (inflow=outflow) but i cannot because i have to tell the model that {init} (0 in the DELAY FIXED function) follows the PULSE TRAIN pattern (the order arrives every 7 days) . How can i do that? is there a way because no matter what i do it brings back the order rate (i.e 200) for every time step and i want this number to appear only on specific times (every 7 days). By the way I use VENSIM.
Looking forward for some help.
Irene
Re: COMBINING PULSE AND DELAY
Can you post the model so we can take a look to get a better understanding?
irene
Post by irene »
I have it posted. All i want is to bring it to equilibrium.
Thank you for your help.
Irene
test.mdl
(2.44 KiB) Downloaded 179 times
You will have to do something like I've done in the attached model (deal with the orders during the initial period).
test.mdl
(3.36 KiB) Downloaded 192 times
irene
Post by irene »
thank you very much.
i have two questions.
1. do you think it is better to use "Time >=INITIAL TIME" in the "if then else" formula in order to include time = 1?
2. in the order receipt rate i have a value at time 21 and not 22 as i should and therefore the 7 days interval changes and supply line becomes negative at time 22 (it is because of the Time < Input Replenishment Time in the "if then else" formula) . I want my level to be 0 at all times to have equilibrium. What should i do? (i have included the model with the alteration).
thanks again,
PS: please bear in mind that i am self-tough and my background is poor, so if you find the above naive :oops: , feel free to tell me !!!
test.mdl
(2.44 KiB) Downloaded 168 times
irene
Post by irene »
i found it... :D
thanks for your help.
irene
