Bar Graph in Venapps
emcgeachie
Post by emcgeachie »
Can you please advise how you can show a barchart in venapps. thanks
Re: Bar Graph in Venapps
Something like
TOOL,"SP1",0,60,100,40,,,WORKBENCH>BAR
As long as "BAR" is in the analysis toolset you have loaded, it should display the chart.
More info at
http://www.vensim.com/documentation/ind ... ?24930.htm
Are you having trouble displaying a bar chart?
emcgeachie
Hi thanks for the advice - I managed to get it to work - however - I wanted to have two bar charts side by side in Venapps - however when I do this its seems to put two chart outlines, but when I test the screen the graphs are the same - suggesting it is showing one input file but I have selected two different variables. thanks
Can you post the code for the screen in question so we can see what you are doing?
