I'm looking for a bit of clarity on importing data...
(1a) When you save a data variable as a .vdf, does it just save that variable?
(1b) Whereas when you save a simulation run as a .vdf it saves values for all variables in the model?
What's the best way to import a subscripted data variable (without using GET XLS equations...I want to import it and convert to .vdf).
(2a) Specifically, when I import from Excel, in the Table to Vdf Conversion box I see an area for subscripts, but don't know how to use this or where to find a reference explaining it. (See image1 attached) Help? How to format the data and configure the conversion?
(2b) Is my subscript limited to 8 elements? If so, the best way to load a variable subscripted by more than 8 elements?
(3) Finally, I really forgot how do do something: How you you link a data variable into an equation? See attached model.
Many, many thanks!
Best wishes,
Sarah
Importing data as .vdf
- CFC2.mdl
- (3.06 KiB) Downloaded 518 times
- image1.jpg (79.26 KiB) Viewed 5566 times
Re: Importing data as .vdf
Can you explain a little more what you mean here? Are you exporting a dataset to save an individual variable?(1a) When you save a data variable as a .vdf, does it just save that variable?
Correct. Everything is saved (unless you specify a savelist).(1b) Whereas when you save a simulation run as a .vdf it saves values for all variables in the model?
Use a format similar toWhat's the best way to import a subscripted data variable (without using GET XLS equations...I want to import it and convert to .vdf).
time 0 1 2 3 4
some var[sub1] 0 2 3 5 6
some var[sub2] 0 2 3 5 6
some var[sub3] 0 2 3 5 6
Make sure the file is either tab or comma delimited.
Ignore this. It's easier to both read and work with if you just list them as I have above (the documentation for this is at(2a) Specifically, when I import from Excel, in the Table to Vdf Conversion box I see an area for subscripts, but don't know how to use this or where to find a reference explaining it. (See image1 attached) Help? How to format the data and configure the conversion?
http://www.vensim.com/documentation/ind ... ?23465.htm)
No. You can only have 8 subscript ranges in Vensim, but each range can have many elements.(2b) Is my subscript limited to 8 elements? If so, the best way to load a variable subscripted by more than 8 elements?
Use data variables in the same way you use any other variable. Eg(3) Finally, I really forgot how do do something: How you you link a data variable into an equation? See attached model.
"some data" is a data variable.
some calculation = some data / 2
Thank you!
Everything has come clear now : )
Best wishes,
Sarah
Best wishes,
Sarah
