Hi there!
This is my first time posting here...and first time developing a Sable interface in a while.
I'm trying to use the SubScript Grid command to let the user edit an array of subscript constants during a run. The command brings up a nice, convenient grid that's easily editable...but when I click on the OK button, it takes like a (whole) minute or so to "write" and return to the app. If I click on the red X to close the window, this happens instantaneously. Any ideas why the lag?
Thanks,
Lou
Slow Response Using SubScript Grid Command
Moderator: Administrator
Re: Slow Response Using SubScript Grid Command
Can you post the offending screen to me?
I might be able to post a screenshot, but the application itself it's on a standalone system with high security. Is a screenshot sufficient?
Lou
Lou
A screenshot doesn't help at all. I need to be able to re-create the problem to have any chance of giving some advice.
The screen itself does not contain any data, if you can just email that to me I can have a go.
