lookup
oludot5
Vensim version: PLE+
lookup
Post by oludot5 »
hi there,
Please, is there a way I can create a lookup to accept the time step as the input?say, for example, A= 8 for time 1, A= 6 for time 2.....
Re: lookup
Try this (you will need to add more x/y pairs if you want a lookup for every time in the model).
lookup table ( (1,8) , (2,6) )
Re: lookup
oludot5
Re: lookup
Post by oludot5 »
tnx, but what variable name do I give the time step (round of simulation) in the lookup function...I still dont get how the lookup variable will accept each iterative time count as the input to produce the lookup output
Re: lookup
Is this what you mean?
lookup result = lookup table ( time )
oludot5
Re: lookup
Post by oludot5 »
thanks!
Re: lookup
Since Vensim is oriented toward continuous time simulation, there is no variable for the iteration number (or round) of the simulation. There's Time, which is sliced into TIME STEPs. If your TIME STEP = 1, it's easy to work out the "round", though this its typically not a good choice to rely on such a discrete count, because it will change if you change TIME STEP, which one should generally do as a test for numerical stability. Certainly there are times where discrete time is useful, but it can be tricky to rely on it in general.
