How to get the List of dataset loaded for simulation
Paul Anim
Post by Paul Anim »
Hi All,
I am using MENU>LOAD_RUN|? in a vb.net program to open the dialog box to load the datasets.
Below is the sample Vb.net code I used
 Dim result As Object
 result = vensim_command("MENU>LOAD_RUN|?")
I want to know how to get the (names or counts)of the list of loaded datasets for the simulation.
Re: How to get the List of dataset loaded for simulation
Paul Anim
Post by Paul Anim »
Thanks very much.
I am having a difficulty on how to call the vensim_get_info function especially on how to supply the variable(s) to the function.
Below is my sample code
Dim testresult As Object
        Dim testbuf As String = ""
        testresult = vensim_get_info(10, testbuf, 500)
Try the following. The string you are passing to Vensim was zero length ("") but you are telling Vensim that it is 500 chars long.
Public Declare Function vensim_get_info Lib "vendll32.dll" (ByVal infowanted As Short, ByVal buf$, ByVal maxbuflen As Short) As Short
        Dim nMaxStringLen As Long
        nMaxStringLen = 500
        Dim sBuffer As String
        sBuffer = New String(" ", nMaxStringLen)
        nResult = vensim_get_info(10, sBuffer, nMaxStringLen)
Paul Anim
Post by Paul Anim »
thanks alot for your help
