Optimisation Crash
Optimisation Crash
I am running Vensim Pro 6.0b under Windows XP. I am trying to calibrate a simple two stock (Potential Adopter & Adopter) diffusion model. But every time I try optimising it, the system crashes. Any insights?
Re: Optimisation Crash
We need to know a little more - can you post the model and your control files? Upgrading to 6.1 could help, though I don't recall any optimization specific bug fixes.
Hello Tom,
The model files are attached in a ZIP file. I upgraded to 6.1c. The incidents are fewer but still it crashes.
Thanks for the help.
Rahul
Rahul
- IoSGrowthApps.zip
- (3.77 KiB) Downloaded 186 times
This works fine for me on Win7 6.1c - I assume you're on a Mac though? I'll move it over and give that a try.
One thing that would help quite a bit here is to put upper and lower bounds on all your variables. Even if you can't determine narrow limits a priori, searching from 0 to 1 billion is a lot better than searching from 0 to infinity.
Actually I see that you're using XP so I tried that and I can replicate the crash. It works fine on Win7 and Mac.
Your model generates floating point errors in its base run. Resolving those (try a much smaller time step for one thing), plus adding parameter bounds, will solve the problem, though it shouldn't be happening.
Thanks Tom.
I did suspect XP as the culprit. My student ran it on Mac and there was no problem. I shall try fix the bounds. Hopefully that would settle it. But is you optimizer assured to give global optima? I would like to know more. Could you direct me to a good resource?
Rahul
Rahul
The optimizer is only statistically likely to find the optimum if you use multiple start for long enough. This is true of all global optimization approaches that can't exploit problem-specific information. If your payoff surface is rough (many local optima), other approaches might be better, including the SA variant of the new MCMC algorithm ( http://www.vensim.com/documentation/mcmc_sa.htm ). However, this is unlikely to be necessary for a simple calibration problem.
