Hi people,
Where I can find some good docs about how to use vensim with java?
Thanks a lot!
Cristiam Mercado
Universidad de Cartagena
Colombia
Vensim.jar
Re: Vensim.jar
Your profile has you as a PLE user. Is that correct? If yes, you cannot use Vensim with Java, you will need DSS.
Re: Vensim.jar
Oks... Thanks!Administrator wrote:Your profile has you as a PLE user. Is that correct? If yes, you cannot use Vensim with Java, you will need DSS.
Re: Vensim.jar
Can you help me with the documents about the conection? Web pages, examples, some things like that!
Re: Vensim.jar
No. If you are using PLE, you are not licensed for using the Vensim DLL.
