VENSIM 6.1C Issue
cjansen
VENSIM 6.1C Issue
Post by cjansen »
Having an issue with Vensim 6.1c.
I create a model with a single variable in it. I give it the constant value of 2014 and run the model. If I then look at the value over the course of the model run (either as a graph or the table output) it now displays as 2010. If I change the value to 311,111 and re-run the model it shows up as 311,000. If I change the value 123 and re-run it shows up as 123. Basically any value over 1000 is being effected.
If I change the variable to a stock with a starting value of 2014 and then increment it by 1 at some point during the simulation it is still shown to be 2010 for the entire run. Although the graph does show a step at the time I make the increase but the scale says the increase was from 2010 to 2010.
Not sure what is going on. I went back to Vensim 5.11 and the issue does not occur so it seems to me to be something associated with 6.1c.
Any help would be greatly appreciated.
-Chip
Re: VENSIM 6.1C Issue
Right click on the table tool and turn off pretty number formatting, that will hopefully clean things up.
cjansen
Post by cjansen »
Administrator wrote:Right click on the table tool and turn off pretty number formatting, that will hopefully clean things up.
Thanks. That fixed the table issue.
Is there something similar to fix graphs?
When using the graph tool on my stock it only shows it going from 2010 to 2010 not 2012 to 2013.
daew
Newbie
Post by daew »
Did you solve problem with graphs? I have similar issue.
