Sketch comment
Vishah
Sketch comment
Post by Vishah »
I would like to check if there has been changes made to the Sketch comment functionality in the Vensim 6.2? I used to draw a box and added background color to separate different sub-models in one view. However, I noticed last week that I am unable to have this function - that is, the sketches are not send forward.
Can someone let me know what happened to this functionality.
Vishah
Re: Sketch comment
I assume you are using Vensim, is that correct?
And can you post a model demonstrating what you mean?
Vishah
Re: Sketch comment
Post by Vishah »
Yes, I am using vensim. Attached find a simple model demonstrating my question.
Test model 1.mdl
(2.78 KiB) Downloaded 449 times
Rafael
Re: Sketch comment
Post by Rafael »
Rafael
Test model 1.mdl
(2.74 KiB) Downloaded 474 times
Vishah
Re: Sketch comment
Post by Vishah »
Many thanks Rafael!
Re: Sketch comment
On the bottom toolbar in Vensim, there is a button to "Push the highlighted words to the background". Select the comment, then click the button and it should give you what you want.
