LOADMODEL does not work from Excel
Hello, I am trying to run a Vensim model from Excel through the DLL-interface.
To test things I have changed the example code in vendll.xls so that Excel and Vensim work in the directory in which both Excel and Vensim are located.
Sub Get_Vensim_Info()
Dim buf As String * 512
Dim MyPath As String
MyPath = ActiveWorkbook.Path
ChDir MyPath
result = vensim_check_status()
result = vensim_command("SPECIAL>LOADMODEL|worldapp.vpm")
Problem is that the model is not loaded. Result equals '6' after vensim_check_status() - which is confusing as I run this on a freshly booted machine without starting Vensim before testing this - and '0' after loadmodel.
Any ideas?
Win 7 64bit & 6.0b
ChDir MyPath
Any ideas?
Win 7 64bit & 6.0b
Re: LOADMODEL does not work from Excel
What makes you think it's not loaded? Getting a 0 from check_status after a LOADMODEL could be normal.
What if you call vensim_get_info with 5 for the current model name? Or issue a MENU>RUN|o command?
Thank you for the swift reply. Apologies for being to brief in my descropition: If I let the vba-code of the demo continue to run all vensim_get_info is empty which makes me suspect the loadmodel does not work. I have a similar issue with a model I have developed where the Run has no effect. I hope this clarifes my problem.
What happens if you put the full path into loadmodel?
Putting the full path in the LOADMODEL has the same outcome
Is the result from vensim_command("SPECIAL>LOADMODEL|worldapp.vpm") a 0 or 1?
0 (in all tests)
Can you upload your code so we can take a look? Zip the directory you are testing with and then we can try running it on our machines.
See the attached. I took the vendll.xls and included the directory change as indicated in my first post.
- Test.zip
- (40.59 KiB) Downloaded 935 times
It works fine for me.
Do you have the Vensim model reader installed as well?
No - I don't think so. In the Start menu / Vensim there is only a reference to Vensim DSS.
What happens if you run Get_Vensim_Info() in the attached? It should fill in the cells F21-Z21 in the spreadsheet.
- Test.zip
- (42.62 KiB) Downloaded 796 times
All cells are empty. I single-stepped through the macro and length = '-1' and buf = ''
Can you try putting it in a different path (eg, c:\test)?
Tried again and no difference. (To mitigate that possible factor I incuded the forced path change in the macros)
Do you have a vendll32.dll file in c:\users\public\vensim? Or in c:\users\public\vensim\dll?
If so, delete it and then what happens?
No, I do not have a vendll32.dll in any of those directories. I did a search on C: and I have the dll in
C:\Users\'Username'\Vensim\dll
C:\Users\'Username'\Appdata\local\Vensim
C:\Windows\SysWOW64
and in the directory the Excel file and the model are located.
All dlls have the same length and save date.
C:\Windows\SysWOW64
I think you will need to reinstall Vensim.
Then make sure you have deleted the DLLs from C:\Users\'Username'\Vensim\dll and C:\Users\'Username'\Appdata\local\Vensim
Do not copy anything into C:\Windows\SysWOW64.
