Move variables and calculate it into a vector
Hi, i'm trying to move variables over time into a vector, but i can´t. For example, I get a subscript i, so my vector Xi is [7 2 5 4 8 0 0 0] in t=0 (get from excel). In t=1, I need to get a new vector X'i = [0 2 5 4 8 3 0 0], for t=2, [0 0 5 4 8 3 9 0] and so on. First question: can you help me to do this?
Second cuestion: in the last postion of these vectors (no zero) I need to make some calculations. I mean, in t=1, I need to calcultate the 3 and in the same way, in t=2 the 9. In summary, I have to calculate just one value in the vector and put in a specific position.
Thanks a lot!
Thanks a lot!
Re: Move variables and calculate it into a vector
Can you post the model you have been experimenting with? I do not understand what you are trying to do.
Hi, this is a post of my model (in Excel). I would like to reproduce this Excel model in Vensim. My starting point (t=0) is the column B (in yellow). The column A shows the subscripts.
Then, i need to calculate in the next iterations (t=1, 2,...n) the column values shown in the Excel file.
It is possible to do this en Vensim?
Thanks again...
Thanks again...
- Vectors.xlsx
- (20.95 KiB) Downloaded 800 times
That spreadsheet has no equations in it.
Are you trying to import this as data in Vensim? Or are you trying to replicate the values?
Sorry, wrong file. I'm trying to replicate the values. My starting vector is the column B (yellow) and from this point (t=0) I need to replicate the values of the following columns.
Thanks.
Thanks.
- Vectors.xlsx
- (37.18 KiB) Downloaded 838 times
I've attached a model that does some of what you need (you will need to complete the rest).
- demo.mdl
- (2.94 KiB) Downloaded 919 times
Thanks a lot!
One more question: how can change the last value (position) of each array with a new customized calculation?
I mean, if I have the following array V=[1 4 3 6 2 8] in t=0, I need in t=1, calculate a new array V*= [14 3 6 2 8*2], for t=2, V**= [1 4 3 6 2 16*0.6] and so on.
How can I do this in Vensim?
Thks again
Thks again
You will need to use an IF THEN ELSE statement (something like "if then else ( subscript_range = xxxx , y,z)". See the equation for "outflow" for something similar.
Yes, but the point is that I need to use the last value of of the previous vector. Again, in t=0, V=[1 4 3 6 2 8], so in t=1, my new array will be V*= [14 3 6 2 8*2], using the last position, e.g. the eight (8) value from V. My problem is that I can not (I don't know how) use this value (in this case, the eigth).
Thks.
Thks.
The attached model has a value that corresponds to the last value in the vector. You could use this with an IF THEN ELSE to change the calculation.
- demo.mdl
- (3.39 KiB) Downloaded 852 times
