hi guys
as you know in DELAY FIXED( {in} , {dtime} , {init} ) we can't start delay from a particular day but how can i use a function like this that has a start time for delay ?
i want that delay starts from time T . for instance {in} = 1 , {dtime} = 3 , {init} = 4 but delay starts from day 2 .
for example :
--------- day: 0 1 2 3 4 5 6 7 .....
arrival rate : 1 1 4 4 4 1 1 1 .....
with best regards
need some help about delays
Re: need some help about delays
I don't really understand your question, it would really help if you posted what you have tried.
Can you just use an auxiliary that has IF THEN ELSE in it? For example,
A TEMP = DELAY FIXED (b,c,d)
A = IF THEN ELSE ( time > start time , A TEMP , 0 )
first tnx for your responseAdministrator wrote:I don't really understand your question, it would really help if you posted what you have tried.
second : the question is : suppose that the normal arrival rate to a Box variable is 3 person/hour . now i want that arrival rate becomes 4 person/hour in the second and third days and then it returns to its normal value ( =3 person/hour) .
in other word , i want that arrival rate be like the below image:
http://i58.tinypic.com/25znj2f.png
Can you use a lookup table?
Maybe the STEP function is what you're looking for. Please take a look at my model.
Have a nice day,
BP
Have a nice day,
BP
- STEP.mdl
- (1.35 KiB) Downloaded 418 times
bppro wrote:Maybe the STEP function is what you're looking for. Please take a look at my model.
Have a nice day,
BP
that's what i need . very very tnx my friend .
my friend , I thank you very much too .Administrator wrote:Can you use a lookup table?
i find another solution : 3 + pulse ( 2 , 2 )
