Different maximum values.....
lorenzo.cioni
Post by lorenzo.cioni »
Hi everybody
pliiiisss look at the attached model... I need to understand why the two gaussian curves (one obtained with a mathematical formula the other with a Vensim model) show such different values at their maximum (one is correctly at 1 the other at 0.008).
Best regards 8) 8)
Lorenzo
TEST_gaussiandestribution2mod.mdl
(4.25 KiB) Downloaded 703 times
Re: Different maximum values.....
The expression for the Gaussian is incomplete. The full pdf is:
1/SQRT(2*pi)/sigma*EXP( (x-mu)^2/2/sigma^2 )
That partially reconciles the two. They still differ, but I don't understand the rationale for the DIFF version, so I can't really comment on that, except to point out that it doesn't work for sigma=1.
lorenzo.cioni
tomfid wrote:The expression for the Gaussian is incomplete. The full pdf is:
thank you a lot.... a really stupid mistake.... the rationale of the Vensim model is to generate the Gaussian dynamically and non through a formula....
Lorenzo
What's the real world explanation of what you're trying to accomplish here?
lorenzo.cioni
tomfid wrote:What's the real world explanation of what you're trying to accomplish here?
I really don't know... it is included in a bigger model from one of my students as his final project so he is still working on it...
Regards
LC
One way to generate an approximate Gaussian dynamically is to use a delay chain with a lot of levels. The SMOOTHN or DELAYN functions are convenient for this. A single level of a smooth or 1st order delay is an Exponential or Erlang(1) distribution. As you reach a large number, it converges to Gaussian. The output of a SMOOTH3 already looks pretty close if you feed it a PULSE input.
lorenzo.cioni
tomfid wrote:One way to generate an approximate Gaussian dynamically is to use a delay chain with a lot of levels. The SMOOTHN or DELAYN functions are convenient for this. A single level of a smooth or 1st order delay is an Exponential or Erlang(1) distribution. As you reach a large number, it converges to Gaussian. The output of a SMOOTH3 already looks pretty close if you feed it a PULSE input.
thank you a lot for this precious suggestion...
Best regards
Lorrenzo
