Calibration
Calibration
Hi good morning
I ve basic questions about calibration and I would like to know how to proceed:
I'm simulating land-use change in a territory. I've the real data observed between 2000-2009 (land change maps) ans I'm doing a simulation for a period of 30 years.
I just have the data of few parameters for the existing period (before 2009) and I consider a lot of parameters fix in both projected and existing period.
I'm actually in the step of calibration and testing the parameters, I built all the land-use model (from 2009 to 2038) in the PLE version, but now, I'm quite blocked with the Sensibility analysis to test the entry parameters and the calibration step. I need to apply a Monte Carlo sensibility analysis to test the parameters.
What do you advice me:
First, adapt this model to the existing period (2005-2009) and after testing the sensibility of the parameters and observe the differences between projected and real period? How to do? What function can I use to do this calibration and parameters adjustments in Vensim PLE or PLE Plus.
Thanks.
Claudia
Thanks.
Claudia
Re: Calibration
You need two things to calibrate:
1. a payoff or objective function
For calibration this is typically something like the weighted sum of squared residuals between model and data, or (for robust estimation), absolute values of residuals. You can write equations in your model to calculate this.
2. a list of parameters to vary to improve the fit, and an algorithm for doing so.
If you have only a few parameters, you can use sensitivity analysis for this, though it may take several iterations. Your sensitivity file must perform a multivariate sampling over plausible ranges for each of your parameters. Then you can export the results to a .tab delimited file, and look at which values return the highest payoff.
If you have more than a few parameters, you are unlikely to find a good solution via sensitivity analysis, because the search space is simply too large to explore randomly - you need the optimizer.
Re: Calibration
Tom ,
Thanks for you answer.
Ok for the response of the calibration, but what do you consider to be "few parameters"? I have like 6 parameters.
Just to know the optimizer is only accessible in the Professional Version ?
Thanks you.
Thanks you.
Re: Calibration
Tom, Another question, where can I find the equation relative to the the "weighted sum of squared residuals between model and data, or (for robust estimation), absolute values of residuals" to enter in my model.
Claudia
Claudia
Re: Calibration
The definition of 'few' depends a bit on how fast your model is - you might get away with 6. You could certainly try it to see.
You need Vensim Pro or DSS for optimization. A public research or academic license is cheaper, if this qualifies.
Your payoff might look like the following:
residual = modelvar - datavar
weighted residual = weight*residual
squared error = weighted residual^2
payoff = INTEG(squared error,0)
The key question is how to choose the weight. Normally an appropriate choice is 1/std_error_of_measurement for your data. If you don't know this, you can estimate it iteratively, though an educated guess will usually suffice. If all your data has similar scale and error properties, you can ignore this and use a weight of 1.
You might take a look at Chapter 18 of the User Guide for inspiration.
Re: Calibration
Ok thanks, I built these equations in my model to compare the simulated and original datas and obtain a payoff.
Claudia
Claudia
Re: Calibration
I have 2 data series, but the number of parameters that I am trying to calibrate are more than 7. Is it practical if I have this amount of parameters for calibrating?
Is Vensim able to obtain an optimum value for parameters by calibration?
Re: Calibration
You can calibrate using seven parameters. Are you having trouble doing this?naserprs87 wrote:I have 2 data series, but the number of parameters that I am trying to calibrate are more than 7. Is it practical if I have this amount of parameters for calibrating?
Re: Calibration
No, I don't have any trouble, I am just wondering how many parameters I can calibrate at most. Because I am thinking if I increase the number of parameters, then calibration is not able to find the best value of each of them. And also sometimes, it just chooses the lower bound or upper bound of interval that I have chosen.Administrator wrote:You can calibrate using seven parameters. Are you having trouble doing this?naserprs87 wrote:I have 2 data series, but the number of parameters that I am trying to calibrate are more than 7. Is it practical if I have this amount of parameters for calibrating?
Re: Calibration
The upper limit depends on your model - nonlinearity of parameter interactions determines the number of iterations needed, and model size determines the speed of a given number of iterations.
Getting solutions that are at the limits is usually an issue with the model's payoff surface, not the algorithm.
Re: Calibration
Using random multistart is generally a good way to test/improve the solution quality.
