Unit error when using delay
Hamilton
Post by Hamilton »
Hi.
Consider the attached model. When I use a dimensionless auxiliary variable with a delay function I got this kind of message regarding error on units:
Error in units for the following equation:
#Auxiliary variable>DELAY3>LV2# =
INTEG( #Auxiliary variable>DELAY3>RT1#
- #Auxiliary variable>DELAY3>RT2# ,
#Auxiliary variable>DELAY3>LV3# )
#Auxiliary variable>DELAY3>LV2# --> Dmnl
#Auxiliary variable>DELAY3>RT1# --> Dmnl
#Auxiliary variable>DELAY3>RT2# --> Dmnl
#Auxiliary variable>DELAY3>LV3# --> Dmnl
Analysis of units error:
Units missmatch in INTEG
Has Units: Month
Has Units: Dimensionless
What I get from this message is that a delay function implies some kind of temporal unit and this causes the error. How can I correct it?
Thank you.
unit problem.mdl
(2.2 KiB) Downloaded 205 times
Re: Unit error when using delay
The delay duration has units of months. When it's buried in an equation as a number (12), it's effectively dimensionless, so you need to pull it out as a named variable with units, which also has the benefit of exposing the assumption to testing. There were two other implicit parameters in the model. See attached.
unit problem 2.mdl
(2.68 KiB) Downloaded 245 times
Hamilton
Post by Hamilton »
Dear Tom,
Thank you so much!
