I have just started learning Vensim.I have been referring to MIT OCW roapmaps. One recurring problem which I am facing is when i formulate equation for an auxiliary variable.For example, I have an auxiliary variable called death rate. The equation for death rate is defined as population * death fraction. Whenever i define equation for death rate in this manner, vensim automatically changes it to population * death fractiondeathfraction. it automatically adds death fraction again to the equation.Please help.
problem in formulating auxiliary equation
Re: problem in formulating auxiliary equation
What version of Vensim are you using, and what operating system?
And are you clicking the variable name in the equation box? If yes, are you single or double clicking?
I am using vinsem ple x32 on windows 8. i am not clicking the variables in equation box. i have attached my model, incase if you want to see.The variable fish death rate is creating problems.
- fishing model.mdl
- (2.57 KiB) Downloaded 215 times
Strange. This works perfectly for me, even when I edit the death rate.
Thanks my problem got solved.it was a very trivial thing.
