Sensitivity testing
- Vensim version: PRO
Sensitivity testing
I am using Vensim Pro. I am trying to learn how to do sensitivity testing but can not see the sensitivity graph analysis tool. I need guidance what do I do to perform sensitivity testing? Kind regards to all. Favor
Re: Sensitivity testing
Please see
http://www.vensim.com/documentation/ind ... ?23725.htm
It will show you how to add the tool.
I am using vensim professional. I tried to do what you have advised the message I get is the "sensitivity graph analysis tool is not available for this verson". I thought the professional version has at least all the analysis tools. what do I do next to achieve my modeling goals with vensim? kind regards. Favor
If you click Help->About Vensim, what version does it say you are running?
I've just tried adding the tool with Vensim Pro 6.3G and it worked fine.
I am using vensim professional for windows 6.3D (x32). I have attached the message that pops up. Kind regards
- THIS THE MESSAGE THAT POPS UP.docx
- (138.23 KiB) Downloaded 161 times
Can you upload or email the model to us? And also the toolset?
One thing I notice is that you're pretty short on screen real estate. You might try reducing the icon size via Tools>Options>Toolbars. Then you can at least see if the tool is present.
