I removed the statement (wasn't sure what was wrong with the syntax) then tried "View->As Sketch" again, which now works and I can see the stock and flow diagram. There are multiple views to the model, but in the status bar where I go to switch the views all it says is "Not able to analyze model". I checked View->Reorder and it shows that there are other model views there.vensimOutput=
WRITE(Tau1,Tau2,Tau3,b1 0,b2,b3,Pfz1,Pfz2,Pfz3,PR1,PR2,PR3,Rz1,Rz2, Rz3, alpha, beta 0\
, gamma, rho 0, theta,
At,OMt,L,a4,a5,b4
,mu1,mu2,kappa3, eta el,eta h,om,Ael,Ah,K 0,k1 0,k2 0,k3 0,k4 0,k5,writetime)
Where should I start to resolve the "Not able to analyze model" error? Could it be because of the section I removed from the .mdl file? What was wrong with the syntax in the quoted section?
