How to continue from previous simulation?
pbreach
Post by pbreach »
I have been using vensim_get_state and vensim_set_state to resume a simulation from a previous run but I get the same output + 1 time step rather than one that is continued onwards from the state at the end of the first run. Here is a short example (attached) written using the DLL in Python.
What ends up happening is that when trying to run a second simulation by setting the state as the end of the first simulation, the second simulation only adds one timestep while the rest of the results are unchanged. Do I have to also change the initial and final time of the simulation? What is the proper way to do this? Lastly, how would this be done with a gaming simulation (continue from previous simulation)?
sandbox.pdf
(66.74 KiB) Downloaded 295 times
Re: How to continue from previous simulation?
Can you upload the model as well?
pbreach
Post by pbreach »
Sure thing - here is the mdl and vpm files for the model I was using to test.
coffee_cup.vpm
(28.58 KiB) Downloaded 274 times
coffee_cup.mdl
(1.91 KiB) Downloaded 288 times
