Unable to use GET functions that call excel in Vensim DSS 7.0
Sam001
Post by Sam001 »
When I try to use any of the functions that call data from Excel (e.g. GET XLS CONSTANTS), Vensim asks if I want to ask if I want to add the file name (without the file extension) to the model. It is as if Vensim expects there to be variables with causal links for all function arguments as it does for the arithmetic equations. The pop up message reads "Do you want to add 'Fleet Model Inputs' to the model?" Then the Error line in the equation editor dialogue box reads Use - GET... CONSTANTS('lit1', 'lit2'...) cannot include other expressions." In addition, Vensim replaces the period before the file extension (first argument of the function) with a zero, "0," when I reopen the equation editor dialogue box.
I have followed the documentation in the user guide for this function. I am experiencing the problem in an older model that was working before, in addition to the newer one I am building now. The one change I can think of is that I was working in the previous version of Vensim before, but I have Vensim DSS 7.0 now, which just came out in May. I get the same errors with other GET functions that call excel. Could there be a bug in the new edition? Please advise.
Re: Unable to use GET functions that call excel in Vensim DSS 7.0
Can you upload the model? Or take some screenshots of what you are entering into the equation editor?
It sounds as if you don't have quotes around the Excel file name.
Did you enclose the strings in single quotes? ( ' )
Double quotes " or no quotes will be interpreted as a variable name.
Sam001
Post by Sam001 »
Thank you for your replies. I have attached screenshots in Archive.zip of what I see. (1) I use single quotes, as per the documentation and confirmed by your messages. When I attempt to Close or Check Syntax, I get a (2) popup asking if I want to add Fleet Model Inputs to the to the model. I also get (3) the error shown in the box at the bottom of the equation editor screen. When I hit close again, and then reopen, I see (4) Vensim has replaced the period before the file extension with a zero.
I also tried adding the excel files under Model > Settings and using ?Inputs as the tag to call the file, but that had the same issues.
Archive.zip
(540.71 KiB) Downloaded 185 times
Try using ' instead of `, does that work?
Sam001
Post by Sam001 »
Wow. That seems to have taken care of the error. I feel silly asking, but how do you type the vertical single quote? (I copied and pasted it from the forum to try it as a solution.)
Thank you!
It depends on the keyboard (mine are all standard UK keyboards). On my Mac, it's the key two to the right of the "L" key.
Sam001
Post by Sam001 »
Though the vertical, single quote seems to fix the problem for a moment, the quotes return to the slanted quote and changes the period before the file extension to a zero when I close and reopen the equation editor. This triggers the same issues as before. Is there a way to get vensim to recognize the vertical and slanted quotes as the same?
Sam001
Post by Sam001 »
PS: I am attaching the model in case that helps.
Fleet CoFLows Car Truck Gas Electric0.2.mdl
(10.69 KiB) Downloaded 193 times
The single quote is on the same key as the double quote on an English keyboard. Are you using a different language? What language is your operating system?
Sam001
Post by Sam001 »
Everything I have is in English. My single quote button is two to the right of the L (Mac Air keyboard).
Any ideas why Vensim would change the quote style and the pre-file extension period to zero?
I can't think of a reason; it works fine on my machine at the moment. It's possible that one of the subscript errors causes a parsing problem, but that seems like a long shot. Will investigate further.
In the meantime, I can suggest a workaround:
Instead of the filename, enter '?input' or something like that. Then, when you run, it will query you for the file name (once). Subsequently, you can manage the mapping of the ? keyword to the filename via Model>Settings>XLS Files.
Martym
Newbie
Vensim version: PLE+
Post by Martym »
I am having the exact same problem. Is this issue resolved or still just hanging out there? I just installed 7.1 and there is no change. VENTANA CAN YOU HELP US?
We haven't managed to replicate this on our side. Can you run the models attached to the GET functions in the Help system? Have you tried the '?file' option?
Martym wrote:I am having the exact same problem. Is this issue resolved or still just hanging out there? I just installed 7.1 and there is no change. VENTANA CAN YOU HELP US?
Are you using a Mac as well?
Sam001 wrote:Any ideas why Vensim would change the quote style and the pre-file extension period to zero?
There is no code within Vensim to modify keyboard input (we just get what the operating system gives us).
My first guess if something like this were happening would be to run a virus/malware scan (malware will often monitor keyboard input).
hcpark
Newbie
Post by hcpark »
DSS Mac Version 7.1 Double Precision
Has anyone been able to resolve this? I am also noticing that the thread is recent (July 2017). Could this be a v7.x issue?
I am having the same issues described above, specifically:
1. Excel filename is being changed after I “OK” and “close” the Edit Equation dialog box. I type in:
:= GET DIRECT DATA(‘Filename.xlsx’, ‘Patients’, ‘1’, ‘e5’ )
and it remains so as I “close”. When I reopen the variable, I get:
:= GET DIRECT DATA(‘Filename0xlsx’, ‘Patients’, ‘1’, ‘e5’ )
2. I am also trying to use the Indirect Reference.
:= GET DIRECT DATA(‘?patientInputs’, ‘Patients’, ‘1’, ‘e5’ )
returns “Incorrect/Incomplete Equation”
3. I tried using “non-slanted” quotes. They turn into slanted quote as I type or if they remain straight quotes, they have turned into slanted quotes when I reopen the Edit Equation dialog.
This is now happening on my Mac as well, I'll ask our Mac programmer to take an urgent look.
I've uploaded a new build of Vensim to our website, if you download and install it, the problem should be fixed.
