SENS2TAB supports appending? +
kwile
Post by kwile »
Unfortunately my release, 6.3D x32, doesn't seem to support SENS2FILE. Does SENS2TAB support appending to an output .tab file?
Thanks,
Kris Wile
Re: SENS2TAB supports appending? +
I think so, with the same + keyword.
Easiest thing to do is try it. If the code to append was written prior to 6.3D, then it probably does.
kwile
Post by kwile »
Yes. I've been trying it with no luck. This is the test .cmd file I have been working with.
SPECIAL>NOINTERACTION
SPECIAL>LOADMODEL|PRISM_v3q1a_Max_All.vmf
SPECIAL>CLEARRUNS
SIMULATE>RUNNAME|C3.vdf
SIMULATE>SETVAL|Ulower C3=0
SIMULATE>SETVAL|Uhigher C3=1
SIMULATE>SENSITIVITY|PRISM ind sensit_C3
MENU>RUN_SENSITIVITY|o
MENU>SENS2TAB|C3.vdf|SensRes.tab|*!
SIMULATE>RUNNAME|C4.vdf
SIMULATE>SETVAL|Ulower C4=0
SIMULATE>SETVAL|Uhigher C4=1
SIMULATE>SENSITIVITY|PRISM ind sensit_C4
MENU>SENS2TAB|C4.vdf|SensRes.tab|*!+
MENU>EXIT
Do you see anything glaring about my usage?
My SensRes.tab only saves one of the results sets, either c3 or c4 depending on whether I overwrite C3.vdf.
What does your help file say for SENS2TAB? It's likely that the feature was added when we added SENS2FILE, in 6.4.
kwile
Post by kwile »
OK
I upgraded, and now my old virtual PC operating system says the Vensim.exe is not a valid Win32 app.
<sigh>
How is the Mac version of Vensim DSS these days? Has it been rung out enough to be considered fully functional?
kwile
Post by kwile »
Downloaded the Mac version as a work around.
Vensim DSS opened and looked normal, so I call my command file from the Terminal.
I see the SD model flash open, status being displayed, then it closes without performing any of the tasks. Then the updated Mac version of Vensim won't open and is hung. The app no longer functions and must be uninstalled and reinstalled.
This sequence of events is repeatable.
To be clear, I have NO working versions of Vensim available to do my work.
Help.
Can you email us with a list of the steps you are taking? And if you can include the model and command script, that will help.
kwile
Post by kwile »
OK
Got the Mac version working, by eliminating the Exit and the NoInteraction commands.
It exhibits exactly the same problem I flagged at the top of this thread.
It doesn't append.
I don't suppose I can get my $500 back ...
kwile
Post by kwile »
I figured this out myself.
Replaced SENS2TAB with SENS2FILE in the updated Vensim DSS and finally got the append to work.
You can keep the $500.
I guess.
8)
Kris
What OS is on your old VM?
I believe it's XP (and I've just tried installing on XP, it fails during the installation as there is an operating system function missing).
Right. I've tried the same experiment - XP is missing some needed resources (and Microsoft support for it ended 4 years ago).
