Importing Data to Use as a Search Variable
Priscila
Post by Priscila »
I would like to know if there is a way to import a excel chart as a search data variable. Which function should I use.
Re: Importing Data to Use as a Search Variable
Can you explain what you mean by a "search" variable?
You cannot import a chart, only the data that is used to create the chart. I don't know what you mean by a "search variable" though.
Priscila
Post by Priscila »
For example,
A variable X is input for an auxiliary variable X x Y with subtype with lookup, where I will have a graph that will provide me the output Y according to input X.
I need a function for the X and Y data to be imported into Vensim.
So you want a lookup table?
Don't bother with the "with lookup" functionality.
Search the Vensim help for GET XLS LOOKUPS, this gives an example how to get the data into Vensim and how to use it.
Priscila
Post by Priscila »
Thank you Tom, this video was very useful.
