Giving time series data
I have given time series data as input to my variables. The data is annual in nature. I have set the time step to year in initial settings of the model. However when I am trying to plot the variable it is observed that the values are plotted with an interval of one month. How to rectify it?
Re: Giving time series data
You probably just need to change the unit for Time in Model>Settings>Time Bounds.
After you've done that, you should define and check all your other units.
Can you post the model & data, or a screenshot of a sample of each?
I am attaching model, excel data and graph of one of the variable.
- potential_gwr.xlsx
- (12.28 KiB) Downloaded 1067 times
- well water data.png (6.33 KiB) Viewed 11660 times
- Vensim.pdf
- (36.52 KiB) Downloaded 1248 times
The Year column in your spreadsheet is not numeric, it's text. I'm not sure what Vensim is assuming about the time axis, because you haven't provided the equations or imported .vdf, but I'm guessing that if you fix the timing it will work.
I am unable to understand how to use the imported data in writing equations involving time series. Can you please help me with it. I know this is very small thing to ask for, but as I am new to Vensim it is talking me a lot of time to figure out.
This might be a good place to start: http://vensim.com/documentation/usr16.htm
If my Units for Time is set at Yearly, and my Time Step is at 0.0625, does Vensim read XLS data for time in the monthly or yearly manner here?
I am currently using the VensimDSS (S/N 9510), academic use license although it says VensimPLE on my profile.
Vensim will be looking for time formatted as a decimal year.
If your model runs in years, then input it as yearly data if you can as otherwise things can get confusing.
Are you talking about the units or granularity of the data? Generally it's always better to use the finest time scale you can, given the time step of the model.
