Hy guys, I need help
How can I remove all these lines from the chart?
Thanks,
Help - remove lines
Help - remove lines
- screenshot.692.png (3.96 KiB) Viewed 3146 times
Re: Help - remove lines
Presumably you want to remove all but one.
Without a legend, it's hard to be sure what this is. You need to do one of the following:
- unload datasets using the Control Panel's datasets tab
- deactivate subscripts using the Subscript Control
- edit the custom graph definition using the Control Panel's graphs tab
Sorry, the lines I want to delete are the background ones.
In a custom graph, change the x-division and y-division settings.
For the graph tool, you can change the global setting on the Scaling tab of the Control Panel.
Helped me
Helped me
