Ordered Subscripts
pochoa
Ordered Subscripts
Post by pochoa »
I need to order the elements on a vector from smallest to biggest. I know I can use Vector Sort Order for doing it, but after reordening I need to use each of the elements in a different equation and I don't know how to do it, I don't know how to call the first or the third or the last element on the reordered vector.
Thanks for your help.
The way to do this is to loop through the sorted array.
eg to get element n,
sum (
if then else ( sorted array[subsc!] = n
, sorted array[subsc!]
, 0 )
This loops through the array, and will pick out only the element that has the n.
Hope this helps.
